Re: Int. B 414 won't turn over
Posted by Janicholson on January 19, 2007 at 13:53:07 from (199.17.6.122):
In Reply to: Int. B 414 won't turn over posted by Paul(NS) on January 19, 2007 at 12:39:35:
A battery not under load will read 12+ volts. The measurement needed is the volts when cranking/trying to crank. Connect a volt meter to the posts of the battery (not the clamps) and (in neutral with brakes set) have someone crank it. If the voltage stays pretty high, there is a connection problem, or starter problem. If the voltage drops to 7-8 volts the battery is either not charged, or toast. If it stays high try measuring between the starter input terminal (starter moter side of solenoid) and good ground. If the voltage is low there (6-8volts) the issue is in the battery cables or ground connection. OOOrrr the starter is stuck or shorted. Loosen the starter at its mounting bolts and wiggle it. then tighten the bolts. If it starts then, it probably needs a starter drive. Best of luck, JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
