Re: Add a hyd. Clutch
Posted by MACKY on January 19, 2007 at 18:28:13 from (198.174.3.46):
In Reply to: Re: Add a hyd. Clutch posted by Allan In NE on January 19, 2007 at 08:35:22:
I AM SURPRISED THAT IT DOESN'T HAVE
ONE. CALL A GOOD SALVAGE AND TELL
THEM WHAT YOU WANT TO DO. THE MCV
SHOULD HANDLE IT. A PRESURE LINE
GOES FROM THE BOTTEM OF THE MCV TO
THE UNIT. THEN A RETURN LINE GOES
BACK TO THE ALL--WHEEL DRIVE COVER.
