Re: change over from low comp, to hig compression
Posted by BAXTER on January 20, 2007 at 11:25:56 from (152.163.100.65):
In Reply to: change over from low comp, to hig compression hedi posted by BAXTER on January 19, 2007 at 18:49:33:
ok, i just went to the shead and tried to put the rockers on, they match up where they are bolted down to the head, but where they are supposted to make contact on that little peice of meatal on top of the vales, the rockers do not fit on there...there too short, like if i get them to match up on one side they will be off on the other side
