Re: Need a part!
Posted by CNKS on January 20, 2007 at 11:35:34 from (204.249.178.32):
In Reply to: Re: Need a part! posted by rustinpeace on January 20, 2007 at 11:01:01:
If it is indeed just condensation, run your tractor to get rid of it. Or change your oil more often. If you are getting a lot of water, you have a problem, and what you are doing will do no good. If you have antifreeze and the first thing to come out is the color of the antifreeze, you definitely have a problem, that may be as simple as a head gasket, or worse, a cracked head or block.
