Re: Need a part!
Posted by Janicholson on January 20, 2007 at 14:17:31 from (66.173.50.84):
In Reply to: Re: Need a part! posted by rustinpeace on January 20, 2007 at 11:01:01:
CNKS is correct. Very few engines ever need the water drained out of their crankcase unless it is getting in there from internal coolant leaks. These leaks need to be repaired pronto. If the engine is run for extremely short periods (3 to 5 min) then shut off to cold in humid conditions, I can imagine condensation being in the crankcase, but it will evaporate when the tractor is used for 20 minutes. Check the nature of your "water" bu putting some on a clean piece of printer paper and putting some coolant next to it from the radiator. If they match, it needs fixed, if they don't it needs driven. JimN
