Re: hyd.
Posted by CNKS on January 20, 2007 at 18:10:43 from (204.249.178.32):
In Reply to: hyd. posted by james braley on January 20, 2007 at 17:38:09:
If I'm reading you right, someone installed a distributer mounted pump (live) and removed the lift all control lever because he no longer needed it. The lever mounted on the stub. If the lift all is being used as reservoir for the live pump, and the other outlets AND the pump are there, you can find a control lever and use both. But, it makes more sense to simply add more spool valves. I assume yours has one somewhere.
