Re: change over from low comp, to hig compression
Posted by ChadS on January 21, 2007 at 09:08:01 from (66.228.96.171):
In Reply to: change over from low comp, to hig compression hedi posted by BAXTER on January 19, 2007 at 18:49:33:
Are you sure the assmbly is put together right?? the rockers should be aimed towards each other, if they are aimed away from each other, someone has taken it apart and put them on backwards. That would make one line up, and throw the other one off, side to side,,,, If the springs are compressing to get them to line up, for sure they are on backwards on the shaft. Other than that, its a bolt on deal,,,, can you show us a picture?? Chad
