Re: removing sleeves out of a 460 gas tractor
Posted by Keith-OR on January 21, 2007 at 15:24:18 from (207.200.116.5):
In Reply to: removing sleeves out of a 460 gas tractor posted by Chester T Welte on January 21, 2007 at 11:36:41:
Chester, depends on if you are going to reuse the sleeves or install new ones. If you are replacing sleeve, just run a couple of beads full length of the sleeve with welder. When weld cools down sleeves will almost fall out. If you are doing this with crankshaft still in block BESURE to cover crankshaft with wet rag, to keep slag off the jounerals.
Keith & Shawn
This is the one I built couple years ago..
third party image
third party image
