Re: Goodbye
Posted by Berry450d on January 21, 2007 at 22:26:59 from (64.12.116.65):
In Reply to: Re: Goodbye posted by Hugh MacKay on January 20, 2007 at 10:25:07:
The last I checked nearly all Farmall C tractors had four speed transmission's in them, thus making fourth gear road gear,and wide open they will barely run ten to eleven MPH. I never said I was running fourteen MPH those are your words I merely made the statement I could plant in road gear which is true, I have done it a couple of times just fooling around, and could tell no difference in the stand. There is still no excuse for RUDE, SNOTTY Behaviour. I try not to act that way myself.
