Re: Again the Heads low comp. to a high comp.
Posted by Janicholson on January 22, 2007 at 06:41:12 from (199.17.6.122):
In Reply to: Again the Heads low comp. to a high comp. posted by Baxter-13 on January 21, 2007 at 10:28:43:
I cannot open the picture in the post below, so I may be in the dark. In your post you indicate 6080 DB as a casting number. That is not the 8060 indicated as correct. If you have the gasket from the original head, and the new head that is not working, place the old gasket on the new head and check alignment of holes, and spacing of bores. Ill bet the head is from a different machine. If the gasket looks perfect, try the head over the studs w/o gasket to check alignments of edges and outlets. Check intake and exhaust manifold alignment. Check the total head height from deck of block mating surface to valve cover gasket seat. If these are ths same, I would be amazed. Keep us in the loop, JimN
