Re: Again the Heads low comp. to a high comp.
Posted by Janicholson on January 22, 2007 at 09:55:49 from (199.17.6.122):
In Reply to: Re: Again the Heads low comp. to a high comp. posted by Baxter-13 on January 22, 2007 at 08:38:39:
Baxter, If the "new head still has the issue with the rockers, measure the spring installed height (length of the valve spring with nothing pushing down on it, installed in the head Like the photo. If they are the same, then the valves are probably correct, and all that is left is to determne what you need to do clean, combine parts, or reassemble with a head known to be OK after just cleaning dire and deposits off of it. If they are different, I would believe (as indicated in other posts) that the valves in the new head are for a different engine. Jimn
