Re: Farmall A Carburetor
Posted by Brad in TX on January 22, 2007 at 13:08:42 from (209.137.232.113):
In Reply to: Re: Farmall A Carburetor posted by RustyFarmall on January 22, 2007 at 12:21:00:
You're probably right, I'll bet I wasn't as thorough cleaning it as I thought. I'll let you know what I find and thanks for the help
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
