Re: pos or neg ground
Posted by Nat 2 on January 23, 2007 at 09:59:23 from (64.80.110.27):
In Reply to: pos or neg ground posted by dan the man on January 23, 2007 at 09:48:51:
It IS whatever terminal of the battery is connected to the tractor's frame. + to frame = positive ground.
It is SUPPOSED to be positive ground, but could have been changed any time in the last 55 years:
With the stock wiring, generator, etc, it should be positive ground, but will work equally well with negative ground if you reverse the connections at the Amp meter and repolarize the generator.
If the tractor has been upgraded to 12V with an alternator, 99.99999% of the time it MUST be negative ground.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
