Re: Farmall H Won't Start
Posted by Janicholson on January 23, 2007 at 10:57:50 from (199.17.6.122):
In Reply to: Farmall H Won't Start posted by Mark E Hansen on January 23, 2007 at 10:45:58:
Start by charging the battery (a discharged battery will freeze) disconnect one battery cable to eliminate the possible discharge happening to it. When the battery is charged, With it turned off, use a test light (not a volt meter) and see if the light lights when you touch the removed battery cable and the terminal it attaches to. If it does, it is draining the battery. Bad diodes or a resistance short to ground. Something changed to cause this. See the alternator diagnosis procedures from John T and diagrams from BobM. Battery drain in the search for slot above will also help a bunch. JimN
