Re: Super A transmission front seal leak
Posted by gene bender on January 24, 2007 at 06:02:31 from (67.55.226.214):
In Reply to: Super A transmission front seal leak posted by Greg-N-CA on January 24, 2007 at 05:47:11:
Some have put two seals there as the housing allows for that. I would try a speedy sleeve if the sleeve is long enough to cover the bad area. How deep is the groove could machining 10 thous or so clean it enough. I have done several and have been able to place new seal in position so as not to ride in a bad groove.
