Re: How much compression on a diesel engine??
Posted by Fromjb2 on January 24, 2007 at 20:55:04 from (74.101.67.211):
In Reply to: Re: How much compression on a diesel engine?? posted by dave2 on January 24, 2007 at 19:30:45:
Yes, thru the glow plug hole should be good for pressure testing. If you fix the glow plugs it will probably start properly. We had a B414D with a British build BD154 Diesel with glow plugs and you had to use the glow plugs on the first start of the day unless the outside temp was in the 80F or more.
Good luck
JimB
