Re: Water pumps how to
Posted by Red Dave on January 25, 2007 at 09:16:57 from (66.216.141.163):
In Reply to: Water pumps how to posted by Roger Mills on January 25, 2007 at 08:31:10:
I've put a Super C water pump on a B.
You'll need a Super C water pump, fan belt & generator belt. You may have to modify the generator upper mounting bracket too.
It mounts right up, but you will need to change to a different drain outlet on the pump, but that's no problem, as both are drilled and tapped.
There is an issue with thermostats. I haven't found a way yet to put a thermostat into the upper water outlet yet. The outlet from a Super C does not fit, I've tried it.
