w-6 fioble,s?
Posted by Kirk in kansas, on January 25, 2007 at 18:45:39 from (65.171.115.248):
where do I find hyd part,s for a 51 W-6 standard?
I need the little box, and lever that go on the inside of left fender, and the 2 nipple,s that join it all together, to the hoses that go in that cover on lower left side of seat,
I have a metal stancion on the back for hose,s ,
But it not for a W-6 I dont think?
Need steering gear,drag link,radius rod,& tie rod, they have tab,s welded to them so i cant use them,
somebody tried power steering on this thing, and they had to weld all this suff together to make it work and a dumb steering damper on right side welded to radius rod, and weld,s all over spindle,s too with the drag link, on one side, & steering cylinder on other,
arghhhh
where,s a hood too,
hole cut in end for 12 volt gen,
H & M wheel,s on front end with 7-50-16 mud truck tire,s on front,s,(one side turned backward,s),
dont know if it supposed to have light,s on front or not/
No hole,s under light stem hole,s on side of hood
this thing need,s help BAD!
all botched up
