Re: H4 mag serial numbers
Posted by gene bender on January 27, 2007 at 13:04:52 from (67.55.226.214):
In Reply to: H4 mag serial numbers posted by SKK - Big Red Fan on January 27, 2007 at 09:25:31:
When you consider that all models of A,B,H,M,W4,W6,W9 pluss all the engines that were on combines,balers,power units and then add the numbers would be over probably a million.
