Re: M clutch sticking
Posted by Janicholson on January 28, 2007 at 16:13:36 from (66.173.50.139):
In Reply to: M clutch sticking posted by Fancy Farm on January 28, 2007 at 11:17:07:
One possible not mentioned in the good stuff below is lube on the surface of the flywheel. often from over greased pilot bearing. Disassembly and degreasing the driven disk (or replacing it) and cleaning the flywheel will be about the only way if the brake clean does not help. Stay out of the fumes of the spray, and read about flamibility on the can. JimN
