Re: 1066 hydro pump problem
Posted by the tractor vet on January 28, 2007 at 21:58:05 from (75.19.125.118):
In Reply to: 1066 hydro pump problem posted by 1066 Dairyman on January 28, 2007 at 17:31:17:
Without running some tests to find out just what it is doing and not hearing it it could be a number of things . So here you are going to have to put something else on the mixer wagon and get it in someplace that can hook it up to a flow rater and runa couple quick tests . IT could be that one of the o/rings got cut when the pump was installed , it could be that some shavings from one of the other pumps got into the pressure releif valve and has it parcialy blocked or stuck , tryen to fix a problem like that over the keyboard is imposable .
