Re: 46 A ,no start
Posted by El Toro on January 29, 2007 at 12:56:06 from (152.163.100.65):
In Reply to: 46 A ,no start posted by Bev Moore on January 29, 2007 at 12:32:21:
Are you sure the starter drive is engaging the ring gear? Do you mean the the starter doesn't crank the engine? You should hand crank the engine to make sure the engine isn't seized. You can even start the engine with a crank. You need to make sure its out of gear with the brakes set.
Those starter drives travel several inches when battery voltage is applied to the starter, you need a fully charged battery and you should have 00 battery cables too. All connections need to cleaned at the battery, starter and the area where the battery is grounded. Remove any rust or paint where its grounded. Hal
