Re: 46 A ,no start
Posted by Bev Moore on January 29, 2007 at 13:21:18 from (207.179.165.73):
In Reply to: Re: 46 A ,no start posted by El Toro on January 29, 2007 at 12:56:06:
Thanks Hal,I should have mentioned the starter does engage ,if the motor is turned past either one of the 2 normal stops.When measuring the depth the drive is coming out ,it is only 21/4" out from starter nose mount surface.This doesn"t let the drive engage the ring more than a 1/4 tooth.A new ring gear and drive will not help.The depth of engagement would still be the same unless the drive was different.I don"t even know if there is a long or short drive available.
