Re: Super C - Fluctuating oil pressure when warm?
Posted by Bob M on January 30, 2007 at 18:24:50 from (69.205.124.61):
In Reply to: Super C - Fluctuating oil pressure when warm? posted by tractorsam on January 30, 2007 at 14:58:29:
A pulsing oil gage hand seems pretty much normal for the Farmalls of this era. Both my SH and SM so it. I've seen it also in friends' B, H, MD and others.
The cause I believe is a combination of 2 things: 1 - Fluctuating oil flow (hence pressure) resulting from an oil supply hole drilled in a rotating part (camshaft maybe?) going in and out of register with the pressurized oil feed hole in he mating bearing, and 2 - A sensitive oil pressure gage (ie. a gage with very little damping of the movement)
As long as your Super C is showing 1/2 gage when hot I wouldn't worry about it.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
