Re: 300u Hydraulic worries...
Posted by TDK on January 30, 2007 at 19:38:47 from (64.12.116.65):
In Reply to: Re: 300u Hydraulic worries... posted by JayWalt on January 30, 2007 at 12:39:44:
All the posts you've gotten is good advice, but I'd go with the regulator safety valve. For two reasons - 1) It's easy to remove the cover without removing the whole assembly from tractor. 2) It's the most likely culprit.
Safety valve could be sticking or, as previously mentioned, the orfice plug & screen may be plugged. At the least if this isn't the problem, then you can be sure it's in the valve(s). Send an email if I can be of help, been there - done that!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
