Re: 300u Hydraulic worries...
Posted by JayWalt on January 30, 2007 at 12:39:44 from (70.226.20.153):
In Reply to: Re: 300u Hydraulic worries... posted by Janicholson on January 30, 2007 at 11:45:38:
any ideas why it doesnt matter which valve I use? Now that I say that seems if one valve is deadheading the pump, then the other valve allows the pressure off the pump, it would alleviate it, just like using the culprit valve, which makes sense and would tell me why one has a better effect on it.
Do they make rebuild kits for these valves and blocks?, or are they hopefully just orings which can be had locally. I have no problems with rebuilding them if I know I'm not gonna be spending several hundred dollars on rebuild kits. What are the other 2 blocks I described?
I have replaced the orings that seal them together and to the res a while ago, but havent taken the valves or blocks apart.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
