Re: Will an H bale with.....
Posted by Bruce Wa. on January 30, 2007 at 19:56:21 from (216.160.107.203):
In Reply to: Will an H bale with..... posted by JWin NH on January 30, 2007 at 04:59:44:
Cousin Jake said that his Dad always baled with a 65 massey ferguson on a JD 14t baler. He put a 1000 to 540 adapter on 4030 JD with a cab. Basically he just idled the big tractor and sat in the cab in comfort. I used his trick on my manure spreader and 2940 JD. 1200 rpm on the engine made the 1000pto turn about 540. I did bale hay once tears ago with an H and a JD466 pto baler. Ground was flat, no wagon. This is a 16x18 baler. Had to bump the tractor into neutral alot when the winrow was heavy but got the job done.
