Re: Farmall H Flywheel
Posted by RustyFarmall on January 31, 2007 at 12:06:24 from (216.248.75.134):
In Reply to: Re: Farmall H Flywheel posted by Joshua Lawton on January 31, 2007 at 11:49:36:
Even if it would fit down through the opening, which it won't, that flywheel is much heavier than what you would want to try and hold onto while lying on the ground underneath it.
