Re: Re: Bought a cub....need help
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill B on February 06, 2000 at 18:22:24 from (209.182.66.216):
In Reply to: Re: Bought a cub....need help posted by Bob G. on February 06, 2000 at 17:24:10:
Thanks. I guess if I have the tractor split, I may as well rebuild the engine. It has some blowby, and smokes a bit, so it's probably due.
I found the shims and removed 3 and the slop is acceptable. The looseness in the box is not so bad, with the linkage tightened up, and one steering arm tightened to the wheel shaft.
Post A Followup
: Re: Re: Re: Bought a cub....need help
