Re: Ring Compressor
Posted by the tractor vet on February 02, 2007 at 13:28:55 from (75.19.124.198):
In Reply to: Re: Ring Compressor posted by CNKS on February 02, 2007 at 13:15:41:
ya ain't getting it tight enough , Make sure that your rings are staggered off the wrist pin and on the iol ring you have two retainer rings that hold the expander inplace stagger them off 180 degrees put the piston in the ring compressor and tighten it up then take the handel of the hammer and tap all around the side of the ring compressor and retighten . place it over the hole and with the handel of a 4 # hammer give it one quick rap and she should fly in don't be gental . If this doen not work then you are going to have to get a new ring compressor as yours is streched . Myself i have the one that is a snap on that has the pliers handels and the different size compressors the work like a charm.
