Re: Purpose of a hydraulic check valve?
Posted by JakeF on February 03, 2007 at 07:48:20 from (216.215.19.6):
In Reply to: Purpose of a hydraulic check valve? posted by JayWalt on February 03, 2007 at 07:01:07:
It keeps oil from returning to the sump if the valve is actuated when the engine isn't running. Without it the oil will go to the sump and not fill the other side of the double acting cylinder that the pump would if the engine was running.
