Re: Farmall C?
Posted by Patrick in Illinois on February 05, 2007 at 18:44:48 from (75.23.85.210):
In Reply to: Farmall C? posted by Christie on February 05, 2007 at 18:23:35:
Need to check on the right side of the seat base for the serial number. Will be on a small aluminum plate. If none is there, then we will need casting codes. Example: 10-15-R. Will be on major parts like motor, Trans tunnel, Trans, wheels; most cast parts. Your casting codes should fall within: R-1948, S-1949, T-1950, W-1951. Hope that helps a little. Patrick
