Re: 460 gas hydraulic filter
Posted by Phil in MN on February 07, 2007 at 11:26:54 from (136.234.54.125):
In Reply to: 460 gas hydraulic filter posted by Phil in MN on February 07, 2007 at 11:02:20:
I should have clarified, I changed the hy tran fluid and filter about 2 months ago. I do get some ice in the rear. Is there a way to prevent the water/ice build up such as a larger breather?
