Re: Got Air ??? (pics)
Posted by Janicholson on February 08, 2007 at 06:27:48 from (199.17.6.122):
In Reply to: Re: Got Air ??? (pics) posted by JayWalt on February 08, 2007 at 06:08:15:
At slow speeds the flywheel effect of the input pulley would be even less than at higher speeds. Thus the torque required to spin it would be higher (at particular points in the rotation, at high pressures) I would think your idea of reduced speed is on track, but at 100psi output the compressor torque needed to get it over the top will be serious (as serious as when running at rated RPM. Driving it with a 540 RPM PTO directly would be cool (it would take about half the horse power, at about half the RPM) I see this little FH equipped skid with a short PTO coupling and a modest 50 gallon tank to buffer the pulses. JimN
