Re: cold blooded Cub
Posted by gene bender on February 09, 2007 at 05:21:51 from (67.55.226.214):
In Reply to: cold blooded Cub posted by dave guest on February 08, 2007 at 20:43:18:
12v will start a CUB when its 30 below. #1 you must have bad starter,cables,sparkplugs,connections out of time or something else simple as a 60 cu engine is not that hard for a starter to turn the engine over on 12v. You mite not even have any compression because of bad valves i would first check compression then go from there. Take all the plugs out before running a compression test. We dont care what it reads just are all 4cycls fairly equal then we can progress from there.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
