Farmall A plow questions
Posted by Chad from Michigan on February 09, 2007 at 06:00:57 from (152.72.151.71):
Hello I just bought a farmall A and I am looking to see some pictures of a land plow hooked up.
This is not the one at least it looks like it doesn't use the draw bar flipped around.
The plow comes straight out to a point and has a few holes in the end that goes up under the tractor. It has all the mounting hardware and hand lift for the back. The hand lift linkages are all hard mounted this one doesn't use a chain to lift up the rear of the plow.
Does anyone have any pictures or any info that I can use to see if its all there or I have to go back after the snow melts and look for parts?
Please help
Chad
