Re: Fuel filter change help on D-239 motor
Posted by Chris from Wa on February 09, 2007 at 18:30:53 from (71.212.9.80):
In Reply to: Re: Fuel filter change help on D-239 motor posted by IH250A on February 09, 2007 at 18:18:17:
There should also be a bleed screw on top of your fuel pump. Do the fuel pump after you do the filters.
