Re: Fuel filter change help on D-239 motor
Posted by IH250A on February 10, 2007 at 13:28:45 from (64.136.49.228):
In Reply to: Re: Fuel filter change help on D-239 motor posted by Fromjb2 on February 09, 2007 at 20:04:02:
Thanks Jim, after two trips to napa as someone changed the whole filter assy the painted the filter canister.I had to have them match one up as it seems to be an odd size.I tried to bleed the filter and could get no fuel as when they mounted new filter it was higher than the tank!I took a foot pump for blowing up rafts and drilled a hole through a mason jar lid and installed the end of the air hose into the lid.Held this over the fill neck and cracked the line at the inj pump.It worked like a charm thanks for the air idea.Jason
