Re: still got wiggle room (I know, here we go aga
Posted by no tools on February 11, 2007 at 11:05:58 from (71.79.44.154):
In Reply to: still got wiggle room (I know, here we go again) posted by LA in Wi. on February 11, 2007 at 09:06:30:
Think you will find you problem is on the end of the worm shaft.That supposed to have a st 225 bearing there soneone has probaly got a narrow race bearing there and the worm shaft is walking <> back and forth in the upper bolster bore.steering worm bearing retainer is not meeting bearing race.been there done that.
