Re: 766...Help! I've got the tractor buying itch!
Posted by Marv on February 11, 2007 at 18:06:55 from (71.7.40.193):
In Reply to: 766...Help! I've got the tractor buying itch! posted by DJL on February 11, 2007 at 13:48:12:
The weak spot in the 66 series tractors was sleeve and block cavitation. Check to see if the engine has a water filter. Also crack the oil plug and check for antifreeze in the oil. Another thing would be to test the antifreeze for correct pH. The test strips can be purchased at most automtive stores.
