Re: still got wiggle room (I know, here we go aga
Posted by Grabatire on February 11, 2007 at 21:44:09 from (216.95.83.171):
In Reply to: still got wiggle room (I know, here we go again) posted by LA in Wi. on February 11, 2007 at 09:06:30:
This may not sit well with some folks, but my SuperM had the same problem. I installed the wedge and a 360 degree sector gear which helped quite a bit but there was still too much play between the sector gear and the worm gear, so I had a machinist make a concentric bushing for the top of the vertical shaft. It moved the sector gear closer to the worm and "presto" no more wobble. In the end I had approx. 1" of play in the steering wheel. It only moved the shaft over .050" so the stress on the lower bearing of the vertical shaft was extremely small. For what I use the tractor for it will outlast me and then some.
