Re: Good News and Bad news
Posted by Michael Soldan on February 12, 2007 at 06:54:31 from (24.235.41.226):
In Reply to: Good News and Bad news posted by J.J. from Afton on February 11, 2007 at 19:25:41:
The next time it starts smoking, tap the carb lightly with a screwdriver handle, this will jar the float and if it starts running fine you know you have a float that isn't "Floating" You will then know to take the carb apart and check float setting and adjustment on needle valve
