Re: No Oil on Top
Posted by David MacKenna on February 12, 2007 at 13:03:23 from (152.163.100.199):
In Reply to: Re: No Oil on Top posted by D Slater on February 12, 2007 at 12:38:43:
The head gasket certainly lined up and I can only assume it had the proper holes. Not expecting this problem, I do not recall checking to see if it was mal designed and would block oil flow when I installed it. Certainly that is something I can look into. The cam was not removed and cam/valves are functioning normally so I would not think that is the problem.
