Re: Heating on the head??
Posted by glennster on February 14, 2007 at 07:27:18 from (68.78.75.201):
In Reply to: Heating on the head?? posted by Wide Open on February 13, 2007 at 16:51:59:
you may have cracked the head, or posibly if it had a new seat pressed in the for the valve, it could have dropped. run a compression test on the motor, i would guess that cylinder is going to be low. i would pull the head and have it checked to be on the safe side.
