Re: Cylinder Sleeves
Posted by El Toro on February 14, 2007 at 11:58:15 from (205.188.116.133):
In Reply to: Cylinder Sleeves posted by Dave From Texas on February 14, 2007 at 10:31:58:
What shape is the crankshaft in? It should be measured for wear and at least have it polished.
The block area where the sleeve seals (doughnuts)
are installed need to be thoroughly cleaned. Any scale, rust or dirt needs to be removed. You don't want to have to pull the engine apart again
for any leaks around those sleeves. I would pull the engine it's a lot easier to work on. Hal
