Re: differences in C-123 block questions
Posted by Hugh MacKay on February 14, 2007 at 16:20:17 from (64.228.11.169):
In Reply to: differences in C-123 block questions posted by riverbend on February 14, 2007 at 15:20:40:
Riverbend: I can't give you the exact info your looking for but do have some info. My tractors are as follows plus a 100 of a friend. These tractors all have factory blocks. 53 SA has 354898 R1, 100 has 354898 R3, 130 has 366204 R1 and 140 has 367825 R2. What is the casting date code on the swather block. I thinking somewhere between 58 and 63, since that number falls in line between my 130 and 140. The swather engine probably has an automotive type water pump on fan hub. You didn't say whether your tractor was SA or SC and with or without water pump. That water pump match up could create some problems, not certain. If your tractor is SA currently without water pump that fan hub pump may actually be easier than the older type pumps. You may have to use your current breather. Valve cover with oil fill could be different however all you need do is use your current valve cover. Does the swather engine have hole in crank for pilot bushing? I think that should cover all modifications needed.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
