Re: change over from gas to diesel
Posted by Gary in Mozarks on February 14, 2007 at 17:40:04 from (66.43.47.89):
In Reply to: change over from gas to diesel posted by ole farmall on February 14, 2007 at 17:12:55:
The best answer I can give is to compare it to GM. GM tried to made a diesel engine out of a gas (350) and spent millions on the project before producing one of the worst engines they ever built. Just to many things have to be beefed up to make it work. Even though they made it work, the engines failed so fast that most of those cars were reengined within a few years. Better to use an engine designed from the ground up to handle the compression (at least 4 times greater)
