Re: Delco Alt. 1 wire to 3 wire
Posted by Bob on February 14, 2007 at 19:41:21 from (69.178.229.154):
In Reply to: Re: Delco Alt. 1 wire to 3 wire posted by SuperA-Tx on February 14, 2007 at 16:22:26:
The IGNITION SWITCH cuts off the "excite" current to the #1 terminal, so the battery doesn't run down with the switch "OFF".
The "idiot light", resistor or diode helps to protect the alternator, and stops current from the #1 terminal from backfeeding into the igntion system (distributor ignition) which would prevent the engine from shutting down when the switch is turned to "OFF".
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
