Re: Delco Alt. 1 wire to 3 wire
Posted by Bob M on February 15, 2007 at 06:51:06 from (151.190.254.108):
In Reply to: Re: Delco Alt. 1 wire to 3 wire posted by teddy52food on February 15, 2007 at 06:21:50:
It's pretty simple:
1 - Disconnect the ground cable from the battery (safety first!). Also loosen the alternator drive belt - this makes reassembly easier later on.
2 - Pull the aux wiring connector (2-terminal plug) from the back of the alternator. You can leave the heavy alternator output (BAT) cable connected.
3 - Remove 4 screws holding the alternator halves together.
4 - Gently separate and remove the rear cover from the alternator. The stator winding will come off with the rear cover.
5 - The regulator and brush holder assembly is screwed to the inside of the rear cover - and is now easily removed/replaced. Be sure to replace insulating washers, etc. in their original locations!
Reverse the above steps to reassemble.
Tip: Before sliding the rear cover back onto the alternator push both brushes fully into the brush holder. Now take a piece of stiff wire (a straightened paper clip will work) and insert it thru the hole provided in the back cover, then thru the 2 rentention holes in the brush holder. This will hold the brushes out of the way while you reinstall the rear cover. Then after the rear cover is back in place, simply pull the wire out from the rear and the brushes will drop onto the slip rings.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
