Re: 706 leak
Posted by Tarrpaper on February 15, 2007 at 10:34:18 from (69.179.39.5):
In Reply to: Re: 706 leak posted by Sheepdog in NE on February 14, 2007 at 17:09:00:
Hi say it looks like it is leaking out right behind the throw out bearing I looked from the bottom of the transmission I took off the inspection cover and it just pours out really fast when the tractor is running and the TA lever is forward when I shut it off or pull the lever back it stops leaking. Thanks I hope you can help
